Ca hyd cylinders
phil terrell
01-18-2003 21:46:59
have a 1955 ca both rear cyl. busted --pump problem i think--can i replace these cyl. with 2500 psi 2inch cylinders from a local dealer--i know the mounting can work but what about psi or other problems
rudy
01-19-2003 10:44:51
 Re: ca hyd cylinders in reply to phil terrell, 01-18-2003 21:46:59
i wouldnt be afraid to do it the pump was designed to prduce a max. 3000psi and with 50years of wear on it and a safety factor on the new cylinders u should be allright
rudy
01-19-2003 10:44:37
