Factory power steering wd45
Wayne
01-18-2003 18:00:45
I have recently put a power steering unit on a wd 45 diesel. The slave unit came off of an old 45 diesel that had been in a fence row for about twenty years. I hooked everything up and it works but it is very jerky. There are two 3/4 inch plugs that are on the top and bottom of the valve just bellow where the steering wheel shaft goes into the unit. When the tractor is running I can remove both of these plugs and it is bone dry inside. If I put my fingers over the holes I can feel a vaccuum. Is this normal or should oil be getting up to the valve. If anyone has a schematic of a factory unit I would very much appreciate a copy. Thanks.
