Allis C starter rod??
Dave C
01-16-2003 17:08:03
I am trying to make up replacment starter rods for two Allis C's.Could anybody give the specs(lenth,diameter,size of loop,etc)and maybe a picture or two of it on a tractor?
terry
01-18-2003 06:47:34
 Re: Allis C starter rod?? in reply to Dave C, 01-16-2003 17:08:03
dave if you find one let me know where I need 1 also thanks terry
Rod (NH)
01-16-2003 19:17:58
Hi Dave,
I don't know if the rod I have is for a C or not. I had electric start added to my crank-start '42 B about 30 years ago. The dealer installed a starter rod that went through a small support bracket on the upper side of the battery box, on the end of the box nearest you as you set in the seat (as I recall). It was NOT down low by your right foot as I have seen on some Bs. It was more like the elevation of the choke rod but on the starter side.
This rod is 1/4" diameter steel stock with an overall length of 29.5". The starter end has a 90 degree bend that is about 1/2" long (after the bend) to engage the lever on the starter. There is a small hole near the end of this bend for a retaining cotter pin. The hand end has an almost complete loop of 1-1/2" diameter. There are two slight angles in two different planes (one vertical & one horizontal) between the two ends. Both the bend at the starter end and the hand loop are in the horizontal plane. I no longer have it on my B so I cannot get an installed picture for you. It is a relatively simple thing to make though.
Rod
kevin
01-20-2003 20:37:14
 Re: Re: Allis C starter rod?? in reply to Rod (NH), 01-16-2003 19:17:58
Dave,
Did you get the photos and drawings I sent?
Kevin
kevin
01-16-2003 20:47:31
Rod,
I have a C chassis that might still have the starter rod. If you need me to check, let me know and I'll take a couple of photos of it.
