Ca tractor pulling- more torque
dave in nc
03-11-1999 11:25:08
any advice on getting more power out of my ca, it will have to be dependable-- still earn its fuel working the farm??
thanks dave
Phil Auten
03-19-1999 09:26:22
 Re: ca tractor pulling- more torque in reply to dave in nc, 03-11-1999 11:25:08
Dave,
Same hot-rodding techniques work on these old
tractors as on cars. Look for an LP C or CA,
they had more compression. Either use the head
from the LP engine or have your head milled,
no more than .030. Can't go too high on the
compression or you'll burn a piston. More gas
means more power. Try getting a replacement carb
and modify it (so you can go back to the original
if it doesen't work) by enlarging the main jet a
little. If you use a drill bit, use the smallest
one that just won't go into the jet. Then the next
one and so on until you find the best size. CA's
will respond to these kinds of mods, just be sure
the mods won't get you disqualified!
Good luck,
Phil
Micheal Tomac
03-12-1999 06:51:35
check out
mm
03-11-1999 17:17:21
Stroke it about a .75"
A
03-14-1999 23:04:02
 Re: Re: ca tractor pulling- more torque in reply to mm, 03-11-1999 17:17:21
OH YA YOU SHOULD PROBABLY get A BIGGER TRACTER CA'S ARE NOT VERY TORQUE UPGRADEABLE
Allis man
03-15-1999 01:25:53
 Re: Re: Re: ca tractor pulling- more torque in reply to A, 03-14-1999 23:04:02
Work on the CA it is a work horse.
