Snap coupler 3 pt hitch
ksmith
01-15-2003 19:14:05
I've found a snap coupler 3 pt. hitch (I think). I can figure out if it will fit. But will it fit my wd45. Can someone give me some measurements of one of these so I can make sure it will work or do they fit all of them wd c ca etc.
Thanks in advance
Kevin
kevin
01-16-2003 20:53:23
 Re: snap coupler 3 pt hitch in reply to ksmith, 01-15-2003 19:14:05
Kevin,
My neighbor has a WD with a "factory" snap coupler 3-pt hitch. I have a '58 D17 that I'm about to install the same type hitch as my neighbor's WD. If you need me to take some measurements and photos, let me know.
Gordon
01-15-2003 20:59:36
As far as I know they only had them on tractors with the coupler underneath and the rockshaft on top of the tractor.WD D15not the C,B
CHALMERSBOB
01-16-2003 18:03:42
 Re: Re: snap coupler 3 pt hitch in reply to Gordon, 01-15-2003 20:59:36
I GOT A 3 PT HITCH WITH MY WD AND NOW USE IT ON MY CA. THE DIMENSIONS ARE REASONABLY CLOSE AS MOST SNAP COUPLER ATTACHMENT FIT EITHER TRACTOR
MINE LOOKS TO BE HOMEMADE, BUT WORKS FINE. THE BIGGEST PROBLEM IS TO FIND A GOOD ATTACHMENT FOR THE TOP LINK. I USED A STRAP AROUND THE ROCKSHAFT AND ATTACHED A CHAIN BETWEEN THAT AND THE IMPLEMENT.(ONLY TEMPORARY, I THINK).
HAVE FUN WITH YOUR TRACTORS. THEY DON'T TALK BACK, AND YOU CAN WALK AWAY FROM THEM WHEN YOU WANT TO. BOB
mj
01-17-2003 14:27:59
 Re: Re: Re: snap coupler 3 pt hitch in reply to CHALMERSBOB, 01-16-2003 18:03:42
Those A-C rockshafts work great for converting the Case VA series with mid-mount lift to 3-point! I buy all I can find around here to use on the VAs. You might want to look at the top-link mount I used w/AC r-shaft at link below.
