CA rear lift capability
Captain.n/e,Mo.
01-15-2003 17:30:07
I was told the CA had the same hyd pump as the wd.
How much will the CA lift? Will it lift a 4x5 round bale with a 3 point adapter?
Captain.n/e,Mo.
01-17-2003 14:08:01
 Re: CA rear lift capability in reply to Captain.n/e,Mo., 01-15-2003 17:30:07
Thanks guys. if it'll lift or at least try to lift an 8 foot disk and pull the front end off the ground ,it should lift a 600 to 800 lb round bale.I do'nt mind going backwards to get where I'm going.
Eldon
01-17-2003 22:47:19
 Re: Re: CA rear lift capability in reply to Captain.n/e,Mo., 01-17-2003 14:08:01
I'm not sure what my disc weighs, but I put it on my 170 and I could pop wheelies with it, too.....
RMD
01-16-2003 07:12:30
Generally you will lift the front of the tractor off the ground before you run out of hydraulic power.
eldon
01-15-2003 18:14:52
I don't believe it is the same pump as the WD....some parts may be interchangeable.
It will lift more than the front end can handle as shown in a pic on my webpage....I think it is on page 2.
DanD.
01-15-2003 20:02:21
 Re: Re: CA rear lift capability in reply to eldon, 01-15-2003 18:14:52
It is basically the same pump as a WD or WD45. The control linkage is different, but that's really the main difference.
Eldon
01-15-2003 18:22:58
I'll try that link again...
T.J.-N.J.
01-16-2003 17:04:30
 Re: Re: Re: CA rear lift capability in reply to Eldon, 01-15-2003 18:22:58
Man Eldon I thought I had the Allis bug bad but you have a full blown case of orange fever! Nice collection. T.J.
JWS
01-15-2003 18:32:42
third party image
