Magneto
Lee in Wisconsi
01-14-2003 17:42:19
The owner's manual for my 1947 AC "C" had
specification for magneto "lag" 30 degrees. What
does that mean and where is the 30 degrees set
from? Same specs state "advance" 30 degrees. Same
questions. Sorry I'm so basic. Any help will be
appreciated. Lee.
Rod (NH)
01-14-2003 18:08:30
 Re: magneto in reply to Lee in Wisconsin, 01-14-2003 17:42:19
Hi Lee,
I'll give you my understanding.
1. Magnetos have a built in spark retard for starting. This is a function of the impulse trip mechanism and is not adjustable by any conventional means. This is referred to as a "lag" since the spark is retarded from the normal operating timing. In the case of my B, this is 30 deg, the same as your C. During starting the spark occurs at top dead center of the piston, if the magneto is properly timed to the engine.
2. After the tractor starts and gets up to running speed, the impulse trip mechanism in the magneto no longer provides any "lag" and the spark occurs at the normal running spark "advance" of 30 deg before piston top dead center.
Rod
