AC WD Oil Pressure
Craig Gmyrek
03-11-1999 05:33:45
I have a 51 WD that is a work tractor. The oil pressure normally reads well into the normal range when accelerating and barely in the normal range when idling. I recently noticed that when the tractor was quite hot, the oil pressure was barely in the normal range even when accelerating. After the tractor cooled, it returned to well into the normal when accelerating. Do I have an impending problem? Is the oil pump suspect?
thanks;
-Craig-
Steve
03-14-1999 08:26:06
 Re: AC WD Oil Pressure in reply to Craig Gmyrek, 03-11-1999 05:33:45
Take the oil pressure gauge off and throw away. Put a plug in the hold and work the _____ out of it. Don't worry about it. We have used them for years with very little oil pressure.
A
03-14-1999 23:08:45
 Re: Re: AC WD Oil Pressure in reply to Steve, 03-14-1999 08:26:06
I BELEIVE YOU SHOULD TAKE THE OIL PRESSURE GAUGE OUT AND USE A MASTER GAUGE AND SEE WHAT THE OIL PRESSURE IS . IF THEY ARE THE SAME AND YOU Are that worryed about it put rods AND MAINS INTO THE ENGINE IT IS NOT VERY HARD ON THAT MODEL
G
03-12-1999 18:24:42
My oil pressure reads about the same. It's been that way ever since i've had it and we work the #@*^$! out of it.
G
03-12-1999 18:24:41
Dan D.
03-11-1999 15:03:01
That's pretty much normal for the old AC tractors with the bypass oil system. The manual says that when running wide open and the engine is hot, the gauge should read on o, r or m. If it's reading anywhere near o, then I wouldn't worry. The oiling system on these pump a lot of oil at low pressure. Also, are you using #30 oil, and did you change to a different kind of filter? If you have a filter that lets oil pass through easier, it will lower the pressure reading on the gauge.
