Wdorwd45
chuckster
01-07-2003 17:43:41
ser#133149 witch tractor do i have and also did thease tractors come with a tall head.
Eldon
01-07-2003 20:39:00
 Re: wdorwd45 in reply to chuckster, 01-07-2003 17:43:41
It would be a '53 WD..should have a large rectangular steel plate on the right hand side of the motor. I don't believe you will find a "tall" head on a WD
Brian G. NY
01-08-2003 07:39:39
 Re: Re: wdorwd45 in reply to Eldon, 01-07-2003 20:39:00
The "tall" head was introduced in '50 or '51 with ENGINE Ser.#289001. I have a '50 with the "short" head and a '51 (my Dad's) with the "tall" head.
Jack (Ariz.)
01-08-2003 19:00:00
 Re: Re: Re: wdorwd45 in reply to Brian G. NY, 01-08-2003 07:39:39
I too would like to know where to find the info. on when the tall heads came out. I was always under the impression that they came out on the WD-45 with the power crator engine. However I am not really sure how to tell the tall head from the short head. Thanks for any info--Jack
Tom
01-09-2003 18:48:09
 Re: Re: Re: Re: wdorwd45 in reply to Jack (Ariz.), 01-08-2003 19:00:00
The short head was proir to engine no. 253,490. At least that is what a Deutz Allis parts book I have says.
chuckster
01-08-2003 17:00:05
Thanks for the information.Could you tell me where you got the information on when the tall head was introduced. I also own a 51 but it has the short head.THANKS AGAIN!!!
Brian G. NY
01-09-2003 06:40:22
 Re: Re: Re: Re: wdorwd45 in reply to chuckster, 01-08-2003 17:00:05
I have both the service manual and the Dealer Parts Book for WDs & WD-45s. There is a wealth of info in both. The Parts Book pinpoints the improvements or changes by the engine or tractor Ser. number at which the changes were made. There were updates and improvements made throughout the life of both the WD & WD-45. The WD "evolved" into the WD-45. This is evidenced by the continuation of the WD prefix in the serial numbers of both tractors. The most notable change was the introduction of the larger 226 C.I.D. engine in the "45" which improved the performance to the extent that it seemed like a totally new machine.
Brian G. NY
01-09-2003 06:46:06
 Re: Re: Re: Re: Re: wdorwd45 in reply to Brian G. NY, 01-09-2003 06:40:22
Chuckster, Could you post both the "tractor" and "engine" serial numbers off your tractor? This would help me determine in which year ('50 or'51) the "tall" head was actually introduced. Thanks, Brian G. BTW, I would guess your "engine" ser. # is before 289001?
chuckster
01-10-2003 08:06:31
 Re: Re: Re: Re: Re: Re: wdorwd45 in reply to Brian G. NY, 01-09-2003 06:46:06
51 ser 80718 eng. wd28842pa 53ser#133149 engwd 343856pa I hope this helps
Eldon
01-08-2003 07:43:38
Thanks for the correction, I thought they came out with the PowerCrater engine...
