AC tractor serial number
david sundeen
01-05-2003 05:21:44
have located what appears to be a B model. having trouble locating serial number plate on tractor,where is it located? this tractor is supposed to be a 1938 model. any help would be appreciated. thanks dave
Big Allis
01-05-2003 17:56:47
 Re: AC tractor serial number in reply to david sundeen, 01-05-2003 05:21:44
Bmodel serial numbers are located on top transmission in front of gearshift lever 1938 Bmodel numbrs are 97-11799 allis B mods made from 1938 to 42 had the BE engine the engine nmber is at the rear of the engine block shld strt wth BE-???? bS PRIOR 2 SERL NMBER 101 HAD A WAUKESHA ENGINE IN THM thy also had 6 bolt pattern on the front wheels hope this was of help allises are nice trctrs i have 7 happy tractoring
david sundeen
01-05-2003 06:35:16
 Re: Re: AC tractor serial number in reply to steve, 01-05-2003 05:46:48
thank you for the rapid response.you have described the tractor i have found to a "T". will have future questions when i start restoration. thanks a bunch dave
John in NC
01-05-2003 05:45:51
I have a 1939 B and the serial number is stamped in the cast directly in front of the gear shift. To read it properly I had to take a drill mounted wire brush and remove the paint down to bare metal. The stampings sometimes are fairly light..Good Luck..
