Allis Chalmer D15
Bruce in Ohio
01-03-2003 13:12:53
Have a D15...gasoline engine. Sometimes won't start. The cellinoid will click...but the starter won't engage. Getting worse. I think the starter has a bad spot in it. Any ideas before I dig into it. Thanks
steve
01-03-2003 15:32:57
 Re: Allis Chalmer D15 in reply to Bruce in Ohio, 01-03-2003 13:12:53
might be looking voltage thru old cables or connectors. you can measure the voltage at the starter while cranking (should be 12 volts). or take cables off starter, battery, solenoid, and wire brush and clean everything and reinstall. if any cables look cracked or corroded, replace. After that, you are right, the starter would be the problem.
Gordon
01-03-2003 17:30:20
 Re: Re: Allis Chalmer D15 in reply to steve, 01-03-2003 15:32:57
You might not have power going through the solenoid. I would go from the bat to starter but have it out of gear and key off.I do not want you to get run over.
