WC questions
Tractor Rod
01-01-2003 15:27:26
Just bought a styled WC with non adjustable wide front. 1'st question did they have a mag or dist, also what size rear tires, these are cut down rims.Also what stlye would the rear be spokes, pressed, or cast. Thanks in advance Tractor Rod.
Farmall Daddy
01-02-2003 15:29:54
 Re: WC questions in reply to Tractor Rod, 01-01-2003 15:27:26
I own a WC and it runs an original magneto. The rear hubs are solid cast iron. I pull with my WC and it is original and I run 13-6-28 tires on mine.
Sheila Cole
01-02-2003 15:06:51
I grew up in an AC family C, WC, WD,and WD45.
Our C ,WC and WD were magneto, the WD 45 had a distbutor.
We still have the WD I restored and the 45 we work.
Denny
01-02-2003 12:32:12
I think that some late 1947 WC's were delivered with distribor ignition. I have one with distributor ignition and it is definitely diferent than the distributor on my WD though it would retrofit either way.
JMS/MN
01-01-2003 22:56:14
All the WC tractors had magnetos, WD45 had battery ignition with coil and distributor. I believe WD started with mags, maybe last year or two they might have had battery ignition.
Steve in N.J.
01-01-2003 15:44:51
Rod,
According to the data book I use on occasions, it states the WC was equipped with a mag only. The mag was a Fairbanks/Morse FMJ4B3 or FMJ4B3A. It does mention about an optional 40X2 skeleton style rear wheels, but not sure if these are the spoke wheels that they refer to. Maybe someone else can shed a little more info there....
Steve B.
Tom
01-01-2003 16:47:11
 Re: Re: WC questions in reply to Steve in N.J., 01-01-2003 15:44:51
Spoked wheels were used for a few years on unstyled tractors I think, they were 24". then they went to 28" wheels, steel rims with a cast wheel. I believe the skeleton wheel was the steel wheel with lugs, that is not a pneumatic tire. These were available too.
