Going to look at a CA,,,,,what to look for?
Captn.n/e,Mo.
12-31-2002 08:28:01
I'm going next week to look at and maybe purchase a ca.I just glanced at it before but did'nt get to look at it close. I saw a hand clutch and some sort of lift . It has a wide front and very good tires all the way around.I have heard about transmision problems (jumping out of gear) are something to look for. What about the hand clutch .Is it like a WD or is it a dry clutch? Where can I get some information on the CA?
thanks all..
rudy
01-02-2003 16:00:40
 Re: going to look at a CA,,,,,what to look for? in reply to Captn.n/e,Mo., 12-31-2002 08:28:01
normally the discs arent too bad the springs get weak if memory serves me right there are 9 springs in the clutch pak and they are about 15$ each but u can still get them and the clutch discs from a.c.rudy
thanks guys ,but one more question
12-31-2002 16:45:49
The little AC book was very interesting,and helpful.along with all the information. One more question. Are the dry hand clutch disks still available,either new or rebuilt? without the hand clutch the whole tractor is'nt very useable,at least for me. I plan th use a 5 foot bush hog and a finish mower and a hay rake.Mowing mainly,and the hand clutch is a must.
eldon
01-01-2003 10:44:38
 Re: Re: going to look at a CA,,,,,what to look for? in reply to thanks guys ,but one more question, 12-31-2002 16:45:49
yes
Eldon
12-31-2002 11:43:56
The hand clutch is spring loaded and must be pulled towards the operator to disengage....it operates dry and is a weak link in the CA drivetrain. Many slipped due to improper adjustment or leaking axle seals and were replaced with a solid axle or bolted together. I have 4 CAs and only one has a working hand clutch.
Also check rear rims for rust...they can be expensive. The wide fronts were a little weak and may be bent or welded up....the pivot point on them was a wear point as well. The hydraulic pumps can get sticky and take some time to work, but are easy to work on. Snap coupler hands (if a sc version) can be hard to find if they are missing. Also check for slop in the steering box....good luck!
Nick
12-31-2002 09:37:06
The online book on this site has some some information.
