B Oil Seals
Rod (NH)
12-30-2002 20:39:15
I ran across the interesting web site below and thought I would share it here. It has on-line catalog listings (by size) for Chicago Rawhide and National oil seals, together with Redi-Sleeve (Federal Mogul) and Speedi-Sleeve (Chicago Rawhide) sizes. In the National listings there are part number interchanges with Allis Chalmers numbers.
I am in the process of replacing the belt pulley shaft seal on my '42 B. There were two different seals used in that application: 1) a leather seal on a spiral-grooved shaft and 2) a rubber lip seal on a smooth shaft. Mine is the leather seal :o(. The rubber lip seal will not work properly on my grooved shaft. The two different AC part numbers (207993 for leather and 225450 for rubber) both cross to the same National number - 450444. That is a rubber lip type of seal. This seal has the proper dimensions but should not be used on the grooved shaft.
A Speedi-Sleeve is not available for that particular shaft diameter. The shaft measures an odd 1.367 diameter. I am considering using the Speedi-Sleeve for a 1.375 shaft diameter (minimum 1.371) and installing it with Loc-Tite Stud and Bearing Mount. I would then use the National lip type seal. I do not wish to remove the shaft.
Any thoughts or recommendations?
Thanks,
Rod
