Allis Chalmers D 14
Dennis Cronbaug
12-30-2002 20:21:03
I bought a non running D14.I got it running but when you put it in gear it does nothing.No pto & no go.No hydraulics.Someone had side cover off.Could they have unhooked something?Thank You. Denny From Iowa.
Duey (IA)
12-31-2002 16:26:00
 Re: Allis Chalmers D 14 in reply to Dennis Cronbaugh, 12-30-2002 20:21:03
Dennis,
Look up through the hole in the bottom of the bell housing where you would time the engine. I'm not sure how much you can see but the main drive shaft that goes into the foot clutch should be seen. Be sure the foot clutch has free travel. This clutch drives everything through the main drive shaft. Duey
JMS/MN
12-31-2002 10:49:40
Suppose they put something back together and left out the flywheel, clutch, etc.? If nothing is working you may be missing some important parts in the middle.
Jon
12-31-2002 06:12:22
Hi Denny
this is what i should drive to iowa for?
might as well have no wheels Ha Ha
