Timing Allis WC styled
DC
12-30-2002 12:56:01
I am trying to time my uncle's 1945 WC. The mag was off. Should the mag click (spark) on cylinder #1 when I see the word "fire" in the left side flywheel observation hole under the tractor?
David Maddux
12-31-2002 05:23:29
 Re: Timing Allis WC styled in reply to DC, 12-30-2002 12:56:01
There is an inspection hole at between 7o'clock and 8o'clock on the WC's. Isn't that the inspection hole for timing? Dave.
kevin
12-30-2002 17:41:57
Crank engine so #1 cylinder is on a compression stroke. Rotate engine so that the "Fire" mark is in the center of the inspection port (bottom or "6 o'clock" position of the bell housing). With mag cover removed rotate impulse coupling backwards until the rotor lines up with the lug at the upper LH corner of the housing--the points should just be opening at this position. Hold this position and install the mag. Firing order is 1-2-4-3.
