Could use some help here please...
sHan
12-29-2002 08:38:08
Hi I just got what i beleve is a 1945 AC WD a few weeks ago and I just got a I&T shop manual for it but im having trouble figuering out the oils in it the book says the trans & dif take 17 qts but of what? and what does the hyd pump run on? is it 30 wt like my H or is it hytran? im kinda confused with this book any and all help would be great.....thanks sHan
sHan
12-29-2002 19:17:45
 Re: Could use some help here please... in reply to sHan, 12-29-2002 08:38:08
THANKS FOR ALL THE HELP
bret
12-29-2002 18:53:29
I have a allis wd that gets worked almost every day. I run 10w in the winter & 30w in the summer for the hyd,and 80w90 in the trany/diff case. and also 80w90 in the final drives.
bret
12-29-2002 18:25:26
Gordon
12-29-2002 15:53:44
The WD shift lever is up and down WD45 is curved back.
DAve K
12-29-2002 13:59:25
First WD's were made in 1948. Do you have a WC (hand brakes) or a WD?
Dave
sHan
12-29-2002 14:43:31
 Re: Re: Could use some help here please... in reply to DAve K, 12-29-2002 13:59:25
its a wd not sure on the age i thought they sead it was a 45 must of been a mistake has foot brakes thanks sHan
Ron
12-29-2002 09:00:11
We have always used 10-40 engine oil in our WD-45's Hydrolics... I'm sure the differential uses 140 wt, the Final drives use 140 wt. I am not positive about the transmission.....wheather it is 90 wt, or 140 wt...Hope this helps, some...
sHan
12-29-2002 09:06:47
 Re: Re: Could use some help here please... in reply to Ron, 12-29-2002 09:00:11
the book ive got shows the trans and diff as 1 for the fluid but it dont say what to use. it says 17 qts. so im guessing that they are connected together thanks for the help..
CHALMERSBOB
12-29-2002 18:30:50
 Re: Re: Re: Could use some help here please... in reply to sHan, 12-29-2002 09:06:47
HYDRO MUST HAVE NON FOAMING OIL - NON DETERGENT 10 OR 20 OR BEST OF ALL USE HYDRO TRANS OIL. THE TRANS AND REAR USE 80-90 SAE LUBE AS DO THE FINAL DRIVES. HOPE THIS HELPS GOOD LUCK HAVE FUN WITH YOUR WD.
