Re: wd45
Denny in TX
12-27-2002 07:11:36
You will need to pull the head to find the problem. When you do take off the head, the gasket may be obviously bad. Need to check height the cylinders are above the block surface. You may need to pressure test the head (for cracks) if you can't find the problem.
