WC PULLER
Bruce
12-24-2002 08:14:19
I have been researching for the last two mounths to build puller out of a WC with electric start. From what i have read it seems that a low hour E3 gleaner motor is the best stock motor for the buck versus HP? Now can i strok it out to 5" and use the stock pistons simular to what is done with the wd45 crank in a wd engine will i have valve clearance and not have to much compressoin. What kind of HP coud i expecet with this combination? Am i off base? Please give me your two cents worth and thanks. Bruce
andy
12-25-2002 08:55:16
 Re: WC PULLER in reply to Bruce, 12-24-2002 08:14:19
depending on what year WC it is you can use a Wd45 crank and get 4 1/2 stroke with no modifications needed it just dropes right in. 4 1/8 overbore sleeve kits are available on this site.good luck
Bruce
12-25-2002 11:30:20
 Re: Re: WC PULLER in reply to andy, 12-25-2002 08:55:16
Andy From what most of the poeple say it sounds to me that the wc/wd blocks usually have cracks in them when get torn down. I just thought the e3 was a lot better block to work with. I live in southern Mn. so their are still a few around at salvage yards. I know of a 5" crank thats for sale an so if it would fit in with the motor in its stock form. I would kill two birds with one stone. thanks Bruce.
