Company Logo (800) 853-2651 Shop Now
1953 CA
52 A Boy
12-23-2002 16:02:02
Im working on a 1953 CA Allis Chalmers and i just can't get it to start, i've got new plugs points condenser cap and rotar. But im only gettin 4 volts through to the plugs. Im getting plenty of fuel to it also. Im gonna check the timing tomorrow. Thanks for any advise.
52 A Boy
JustinNY
12-25-2002 06:21:35
 Re: 1953 CA in reply to 52 A Boy, 12-23-2002 16:02:02
52A Boy, 1 other thing pull bowl off carb and check main jet in bottom of bowl, you might be geting gas to the carb but 0 to the engine,This has happened to me 1 time when the jet was plugged. Justin Ny
Phil Auten (Tx)
12-24-2002 11:19:10
When you get those new plug wires, be sure to get copper core wires, not resistance wires. It will make a world of difference. Also, I would get new plugs while I was at it, and go with Autolite 295 instead of the normal 303. This is a hotter plug and will be a lot more resistant to fouling under light use. If you're going to use it hard, stick with the 303 plugs.
After that, timing would be my next guess, even if it ran yesterday. I hope this didn't happen, but it could have bad timing gears and be firing at the wrong time.
My 2¢,
Phil
52 A Boy
12-24-2002 09:44:06
I just put a new coil on it and it still won't start, i will go to town and get some new wires and see if that helps.
Justin NY
12-23-2002 19:28:37
I agree with Steve it sounds like a bad coil! Justin NY
steve
12-23-2002 18:59:01
pull out a couple plugs and put them in the spark plug wires. lay the plug on block and crank the motor. look for the spark at the plug gaps. if you have good white-blue spark o.k., if not, then maybe the coil is bad, assuming the wires are good, and the point wire is not grounded out, and the point is closing and making good contact.
52 A Boy
12-28-2002 06:06:10
 Re: Re: 1953 CA in reply to steve, 12-23-2002 18:59:01
We finally got it running, we switched the spark plug wires around and just kept messing with them and it finally came alive after sitting for 8 months. I feel kind of stupid trying all the other things that I did and not even thinking about the plug wires.
Thanks for all your advice though.
52 A Boy
James
12-25-2002 16:24:24
In addition to what has already been said, be sure you have the proper voltage on the primary side of the coil (wire from battery or ign switch). Remove spark plugs and crank engine. If no spark, keep working your way through the coil and distributor until you find the gremlin.
Today's Featured Article - Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life. ... [Read Article]
Latest Ad: 2 old Dodge Pickup Trucks not running mostly complete early 50s flathead 6cyl stepside box side entry hoods Price 1200 both. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
