Re: Removing Sheet Metal Thanks
CHALMERSBOB
12-23-2002 07:19:18
IF I REMEMBER CORRECTLY THE GRILL GOES UNDER THE RADIATOR AND MUST THEY BE REMOVED TOGETHER GOOD LUCK HAVE FUN
Tom Z
12-23-2002 18:45:25
 Re: Re: Removing Sheet Metal Thanks in reply to CHALMERSBOB, 12-23-2002 07:19:18
Should be 2 nuts and bolts towards the rear,one on each side(also holds generator/ alternator in place) and the front is held in by 2 bolts that thread into the radiator from the bottom.The radiator and sheet metal should come off as one unit. After it is off the tractor you can pull the radiator out of the grill.
