Wc aux tranny
Dave
12-21-2002 20:35:05
I am posting this for a friend. He is thinking of purchasing a WC that has what appears to be an auxilary/hi-lo gearbox that is located between the factory transmission and the rear end. Is this a hi/lo in each gear or is it a extra clutch to make the pto "live"? What would something like this be valued at? Thank you for the help.
oltimer
12-23-2002 17:08:54
 Re: wc aux tranny in reply to Dave, 12-21-2002 20:35:05
poor mans live power,push it out of gear and stop the drive to the wheels but lets the pto keep running . better than digging a slug out of the baler or combine(pull type pto drive). Us old f#### used to run them.
Tony
12-22-2002 18:15:10
Could be an underdrive. Could be an overdrive.
Most likely it is standard disengage found on all styled WC's.
Farmall Daddy
12-22-2002 07:38:45
I have heard of them at tractor pulls. It is a Sherman Underdrive unit. Many guys have been looking for this transmission for it's low gears. If I was him, I would buy it for up to 2700{In my own opinion}.
Joe M
12-22-2002 07:01:27
I posted you a picture of a WC rear disconnect
so you would know what it looks likein the parts & pieces gallery
Dave
12-22-2002 14:34:27
 Re: Re: wc aux tranny in reply to Joe M, 12-22-2002 07:01:27
Thanks for posting the picture. That looks like the unit on the tractor. Thanks again.
Dave Maddux
12-22-2002 06:18:43
What you have is a Sherman transmission unit. They have a low side that is lower than your factory gears, and a high side that is higher than your factory gears, also a neutral that works as a hand clutch. I bought a WC from Larry Swinson that had one of these. I was told that it is a 500.00 item. I let him keep it. I kind of wish I had kept it now. Dave.
rudy
12-23-2002 20:22:35
 Re: Re: wc aux tranny in reply to Dave Maddux, 12-22-2002 06:18:43
how many do ya want for 500$lol rudy
Noly
12-22-2002 01:42:48
It is probably a rearend disconnect. used so the mechanical lift can raise cultivator when tractor is not moving, these are faily common. but it could be a dry clutch also.
