Restoring an Allis B
Sean
12-19-2002 12:45:50
I an restoring an allis B and I wondered wherether you guys had any usefull tips eg: what order to do things for example. I would be gratefull for any suggestions. thanks sean
[email protected]
David Maddux
12-20-2002 05:34:44
 Re: Restoring an Allis B in reply to Sean , 12-19-2002 12:45:50
The way I start my projects, I tear them done all the way, inspecting parts as I do it. When I get it all the way tore down, I start with the last piece and that one with all of the others are an individual project. As you are tearing it down you will be keeping in mind what you need as you are sifting through the salvage yards, or order ing new parts. A lot of help is the auction section on this web site or classified ads. You can even go to E-bay to bid on parts. But first of all if you do not have a repair manual for it, you can bid on these on E-bay. You will need it. Dave.
Justin NY
12-19-2002 13:58:32
Sean, I put the most effort into the mechanical part first,engine,trans,brakes ect...Then use it for awhile before I get into the cosmetic part.In the mean time I hunt down everything I know I will need on the cosmetic end.I do this due problems that might arise and ya already have it all painted and assembled then have to pull it apart and then scratch everything no matter how careful you are. My $.02 worth Good Luck! Justin NY
Steve in N.J.
12-19-2002 14:44:16
 Re: Re: Restoring an Allis B in reply to Justin NY, 12-19-2002 13:58:32
Sean,
I've been restoring antique cars and trucks for myself and my customers for over 33 years, and the first thing you want to do before you pick up a wrench is take a ride to the supermarket and pick yourself up a few different size ziplock bags to put the parts your taking off in them and mark em' where they came off from. This way later down the road as you start to reassemble your tractor, you'll know what goes where because they were marked. I still do that to this day! (helps my lousy memory too) I did that when I restored my B also. If you've taken off some parts that need replacing, put an "X" on the bag so during your resto, you can chase what you need whether it's bolts, nuts, or whatever. Also, buy yourself a can of PB Blaster rust buster. It makes the job go a little easier.The main thing is have a lot of fun!! And if ya need help, ask your questions on this board or the Allis site. The folks that are on these boards are super! You couldn't put all the knowledge that these folks have in a book! Enjoy!
Steve B.
Dick L
12-19-2002 13:38:53
Restoring means different things to different people. To some it means to clean, fix the oil leaks, get the engine running well, and a paint job. To others it means taking every part apart and making sure every bearing, seal, gasket, and parts are as good as they came from the factory. I have seen a C Allis on ebay that was stated to be restored to better than new. However you could see by the picture that it had a B wishbone front axle, auto front wheels, had been switched to 12v, the battery box was gone with the battery out in the open, and a car stearing wheel.
The idea is to do the best job you can whith the pocketbook you have, learn, and have fun doing it.
I will link you to my site and pictures of how I start.
Eldon
12-20-2002 21:30:02
 Re: Re: Restoring an Allis B in reply to Dick L, 12-19-2002 13:38:53
Thanks for the pics, I will be pulling apart a 48 C tomorrow and will follow your procedure.
Jerry
12-20-2002 16:55:47
I have a bad memory but I have a digital camera that stores the pictures on a floppy disc. I take as many closeup pictures as I think are needed to help get my restoration projects back together. Any camera will do but prints cost money and pictures on digitals usally can be reviewed and printed if needed.
