Re: wd45 compression
Ron
12-18-2002 18:34:09
You can use a timing light----aimed up at the flywheel from the bottom. I only remember one mark.....I center it in the opening, at full throttle. If you have 6 volts, you may need to use a 12v battery to power the timing light. When the timing is set right, the governors should be aggressive at anything over an idle..!!
