Justin NY^
12-14-2002 17:20:08
Hello All, I need some advice, I bought a ca about 2 weeks ago and have been trying to plow snow with it .The low down is it will cut out and die with no warning when it gets warm,Then it will pop,fart and moan sometimes.there is no bent push rods and they are all inadjustment.To top it off yesterday I went to move it to put some weights on it and the batery explodes soaking me in acid.For 1 it was overcharging so I fixed that,ruled out fuel flow problems,carb problems.still acting up and figured Ok coil is failing,Changed coil,condensor,points,plugs ,wires,cap, rotor all new and having trouble ,Figurd could be a flaky switch,nope ok short in coil wire,Rewired complete tractor nope,Fuel line was run next to engine behind air cleaner assembly, ran new line outside of air cleaner( Not vapor locking)I am ready to pull the engine out and put in the 1 I just rebuilt but restore is 3/4 way done on that CA.I am completely aggravated ( and stumped).The only thing I can think I DONT KNOwW????? ????? ????? ???? Thanks for any suggestions Justin NY
