Allis Chalmers B
Jerry Claborn
12-13-2002 19:27:46
Tractor looses power when going up a grade. Could this be a problem with the governor?
Steve in N.J.
12-13-2002 21:41:58
 Re: Allis Chalmers B in reply to Jerry Claborn, 12-13-2002 19:27:46
Jerry,
Could be a govenor problem, although it could be a few things. Check the fuel system, and make sure you're getting enough fuel to feed her when she goes under power. Quite a few fellows on this site experienced a fuel delivery problem with those symptoms. Rusty gas tanks are usually the cause for the fuel delivery problems.An inline fuel filter usually is the fix after the fuel line, sediment bowl, carb & tank are cleaned... Steve B.
Diesel Don
12-13-2002 21:39:41
Could be,but make sure it is getting enough gas before you dig into it.Mine was doing that and the high speed mixture was set too lean.I adjusted it and it has run just fine since.
