AC C
david
12-12-2002 15:22:44
OK i've found a C that has the serial # C19878 that needs a mag. and wires. There are trees about 3-4 inches in dia. growing "through" it but it looks like a fairly clean tractor.Tin is straight and all there.How expensive is this one to overhaul?How close is this one to a B?I guess I'll be an AC fan 'cause everywhere I go lately I find one.Is the C engine interchangeable with a B engine?I've found my winter project I guess. Thanks,David
Justin Ny
12-12-2002 16:55:11
 Re: AC C in reply to david, 12-12-2002 15:22:44
David, Congrads on your find I would buy it !!!!! !!!!Engines are easy to over haul I have rebuilt a B and a CA,Engines for the most part are interchangable,parts are also such as pistons and stuff.Dave if it is not stuck make sure you don't turn over until you make sure valve train is free(pull valve cover off and check)If trees are that big I can almost guarantee valves are stuck.if set up a mixture of marvel mystre oil and keresone 1/2 and 1/2 works well.Best of Luck and Welcome aboard,Orange rules Justin NY
