C-valve cover and oil pan
rudy
12-12-2002 15:11:27
i've got a c allis with a solid cast iron oil pan and valve cover.only one i've ever seen and i've seen a lot can someone shed some light on why this is so?
Herb
12-19-2002 09:49:38
 Re: c-valve cover and oil pan in reply to rudy, 12-12-2002 15:11:27
I also purchased a C that has a cast iron oil pan,valve cover and final drive covers it also has an adjustable wide front end. the front wheels are riveted on instead of being bolted on the hub.It also has what appears to be two serial numbers. one in front of the shift lever and one behind it. Which I think is unusual. The numbers are front C386859 and the rear number is 93634G. If any one has any infomation on this tractor I would appreciate it. Her Brady
Dick L
12-12-2002 16:14:23
I have three of them. I saw two others sell at auction. I had ask around and was told that they were rare but I think not at this time. You will find that the final drive covers on it are cast iron as well, at least mine are. The picture back from the pan showes the valve cover.
TractorMike
12-12-2002 16:28:16
 Re: Re: c-valve cover and oil pan in reply to Dick L, 12-12-2002 16:14:23
Hey Dick, How much does that sucker weigh? Sure looks heavy. TractorMike
Dick L
12-12-2002 16:36:22
 Re: Re: Re: c-valve cover and oil pan in reply to TractorMike, 12-12-2002 16:28:16
I never put it on the scales. It is some what heavyer than the stamped. They were not from the engine shown in the picture but I wanted extra weight in the front.
