AC 190
Robert
12-12-2002 08:28:38
AC 190 getting weak, fouling plugs, when idleing after doing any work throws water, about 2 quarts out as hot water...
What is possibly necessary as an overehaul...Sleaves, pistons, bearing, crank??
Chris
12-12-2002 18:56:46
 Re: AC 190 in reply to Robert, 12-12-2002 08:28:38
...block, head, valves, guides, rods, water pump, clutch, radiator, etc., etc.... You can guess as much as you want but till you tear her down you never know. I will advise you to do as much as you can afford and do it correctly the first time. It saves money in the long run.
