Re: WD Allis -- What size engine?
steve
12-10-2002 16:04:03
common problem is rain water getting past shift lever boot and freezing in transmission cavity area. drain the trans, pto, hydraulic area and install new oil. also the final drive probalby have not had new oil in 60 years. i always like to do that to help the old bearings. you need to remove the bottom pans to clean and get the goo out.
Tom
12-10-2002 17:24:07
 Re: Re: WD Allis -- What size engine? in reply to steve, 12-10-2002 16:04:03
You almost took the words from my fingers!! I could only add that with a good boot on the shift lever you are OK, only when they get cracked is there a problem. And a WD is a fine tractor. 201 cubic inches, 34.63 PTO hp if I remember.
Sheila
12-11-2002 18:12:36
 Re: Re: Re: WD Allis -- What size engine? in reply to Tom, 12-10-2002 17:24:07
WD's were classed as a 35 horsepower tractor.
Sheila
12-11-2002 18:12:24
