Engine heater for an Allis CA
Craig
12-10-2002 06:54:32
I'm interested in installing an engine heater on my Allis CA. Does anyone have a recommendation as to which type and in which location will work best? It seems as if the diameter of the lower radiator line is too small and with the metal tubes from the tractor and the radiator, there doesn't seem to be enough room to insert such a heater into the line.
justin NY
12-10-2002 17:42:33
 Re: engine heater for an Allis CA in reply to Craig, 12-10-2002 06:54:32
Craig, I own few Allis's including 2 Ca's and a B and I have not had any trouble starting them this winter even when it was 2deg. out.On the other hand I (had)a cub that had to have a heater.what I used and still have is a magnetic block heater that ya stick right on the oil pan,works good you can pick them up at your local tractor supply for about $25 My $.o2 worth Justin NY
