Hi Eldon,
I can't vouch for the C weights but David is correct for those for the B. The left side B weight is different than the right side. It has some material removed from the lower rear portion on an angle to provide clearance with the different steering linkage on the B. If you look carefully you can see that angle in this photo of my B.
Rod
