WC block part number?
Bruce from Boul
12-05-2002 19:23:48
I have seen WC engine blocks with different last numbers on the part number. Anyone know what that number means? The ones I have found all start with U-3019- but I have found at least two different last numbers. My '36 WC block part number ends in 25 (or 26?). Another block that I would like to buy ends in 8. Anybody have a part book that explains the difference?
Brian G. NY
12-06-2002 06:31:54
 Re: WC block part number? in reply to Bruce from Boulder, 12-05-2002 19:23:48
I don't know too much about WCs but the old Tractor Supply catalog showed the WC block with casting #U-3019. However you had to specify whether you wanted the early block (12 studs) or the late block (15 studs). I would guess that is the only critical difference. BTW, the WD blocks (I have two WDs) have casting number U-3019 as well. It would appear the suffix may not be too significant except that a low suffix number (like 8) would alert you to check whether the block had 12 or 15 studs. I'm surprised the WC "gurus" haven't chimed in here.
Brian G. NY
12-06-2002 06:35:13
 Re: Re: WC block part number? in reply to Brian G. NY, 12-06-2002 06:31:54
I just noticed your earlier post to which you got several responses. Seems like the info those guys provided pretty much answers your question?
Bruce from Boulder
12-06-2002 15:32:02
 Re: Re: Re: WC block part number? in reply to Brian G. NY, 12-06-2002 06:35:13
Thanks, Brian. Your info was also helpful. I just want to make sure before I drive accross Kansas to pick that block up. The drive isn't bad, but it seems like the wind is always in my face when I am traveling in Kansas, both going East & West.
