Fairbanks FMJ
mk
12-02-2002 17:49:35
Hi guys, this question is for a Farmall A, so before you start throwing things at me let me just say a buddy of mine owns a bunch of allises, so I have quite a bit of respect for them. Anyway, the boys on the Farmall board couldn't answer this for me, and I heard a rumor that ACs used Fairbanks, so...
I have a fairbanks (FMJ) Magneto that I think I knocked the timing off on. You see the engine got turned when I was cleaning the points. So judging from the gear(s) that drive the roter, it seems to me that my timing is no longer on.
So does anyone know what the process of getting this guy timed again? Also, if you know what the points should be set at, well that would be great too.
Thanks,
mk
Duey (IA)
12-02-2002 18:05:38
 Re: Fairbanks FMJ in reply to mk, 12-02-2002 17:49:35
MK,
These are the instructions for the ACs so you will have to determine the timing marks for a Farmall and the direction the rotor turns. Inside the big cap the A & C stand for clockwise and anticlockwise so use the one you need when timing the gears. The firing order may be different too. Duey Timing a mag. (FMJ)
1. If you have taken the Mag. apart, the internal gears need to be timed. (Set points at .020)
2. Remove the large cap and line the C mark on the fiber gear with the marked tooth on the steel gear. Tip- turn the engine backwards to get the steel gear tooth to stop straight up and position the C mark on the fiber gear straight down. This times the rotor to the points. It is pretty simple in theory. Like all four cycles, the piston comes to TDC (top dead center) twice for every time the magneto or distributor rotor goes around. The left side of the engine has a hole in the bell housing where you can see the timing mark on the flywheel.("B"&"C") ("WD" &" WD45" The timing mark is found by looking under the flywheel housing for a small hole possibly covered by a small plate held with two wing bolts. The FIRE mark and the TDC mark are located on the flywheel through this hole. Use a little light colored paint to make seeing them much easier). 3. Take out the #1 spark plug, and put your thumb over the hole while hand cranking the engine(best to have all the plug wires off while doing this so the tractor doesn't try to fire) , the cylinder will force air past your finger on the compression stroke. (The other FIRE is the exhaust stroke and has the exhaust valves open so no air will come out of the plug hole).
4. When you feel the air coming past your thumb, look for the FIRE mark on the flywheel. When this mark is centered in the hole, the rotor on the mag should be just lower than the #1 lug on the mag. Looking at it as a clock, #1 lug should be near 10:00. Just before the lug is a plastic stud called the timing stud. Perfect timing is when the rotor points to the timing stud while the FIRE mark on the flywheel is centered in the hole. 5. If your rotor points to 5:00 your mag is 180 degrees off and needs to be removed and the coupling turned till you achieve 10:00. If it is not right on the timing stud, you can loosen the mag and rotate it until it is. 6. Put it all back together and time your spark plug wires 1-2-4-3 clockwise on the magneto cap.
Remember if the rotor is aligned with the timing lug when the fire mark is in the window, you got it right. If it's not quite aligned when the fire mark is in the hole, then you rotate the mag clockwise or counter clockwise until it is. Remember Perfect timing is when the rotor points to the timing stud while the FIRE mark on the flywheel is centered in the hole.
Steve from New Holland
12-03-2002 04:56:28
 Re: Re: Fairbanks FMJ in reply to Duey (IA), 12-02-2002 18:05:38
Duey, your instructions were teriffic. Please don't think I'm being smart, but Fairbanks Morse point settings on the FMJ and the FMX series is .015 Steve
Duey (IA)
12-03-2002 10:09:51
 Re: Re: Re: Fairbanks FMJ in reply to Steve from New Holland, 12-03-2002 04:56:28
Steve,
Check your E-Mail. I sent you the instructions for setting the point gap for a FMJ used on an Allis Chalmers. .020 Duey
mk
12-02-2002 18:30:34
Thanks! The A turn clockwise, so I think it should be a snap to set up!
BTW, where is a good place to get parts? The cap should be replaced, and the points just to do a complete job.
mk
