Allis Color code
Scott
11-30-2002 19:50:24
Can anyone supply a true allis color code that can be taken to the paint shop to be matched?
Rod (NH)
11-30-2002 22:06:19
 Re: Allis Color code in reply to Scott, 11-30-2002 19:50:24
Hi Scott,
Check out the link below for a visual color comparison between the two PPG persian oranges (#1 and #2, so called). You can get either mixed at any place that carries the PPG line of automotive paints. Both are available in PPG's OMNI line in single stage acrylic enamel (w/ & w/o hardener), single stage acrylic urethane and two stage base/clear acrylic urethane.
For example: If you wanted persian #1 in single stage acrylic enamel, you would ask for PPG OMNI MAE 60080. For the single stage urethane, the same, except replace the MAE with MTK.
If you are not familiar with the health and safety aspects of using urethane paints or enamels with hardeners, please investigate before purchasing such materials. I also recommend you obtain the technical data sheet for the material you plan to use before you purchase. That sheet will give all the mixing and application information needed (more than on the label).
Rod
Garri
11-30-2002 21:11:31
In the Winter 1999 issue of Old Allis News they listed some Dupont #'s. I have used them. Here they are. Persian Orange #1: 914966 and 81-844. Persian Orange #2: 921074 and 112-8300. I also have a 6755A Dupont # writen down that I have used. I have some other #'s and info if you need it.
Chris
11-30-2002 20:05:48
PPG#60080=Persian Orange#1
PPG#60396=Persian Orange#2
