Adding Electric Start for Allis B Tractor
Haig Stephens
11-27-2002 05:37:58
Anybody know if an electric starter can be added to an Allis Chalmer B, how to do it...and what/who's parts to use?
Look forward to the help...once again!
Thanks in advance!
Haig
Eldon
11-27-2002 08:25:19
 Re: Adding Electric Start for Allis B Tractor in reply to Haig Stephens, 11-27-2002 05:37:58
I met a guy who took a starter/generator from a lawn tractor and mounted it on the rear of the tractor and ran a belt to the belt pulley. It not only started the tractor but kept the battery charged up.
Steve in N.J.
11-27-2002 06:07:40
Haig,
All B's pre-1940 didn't have electrics. Don't know what year your's is, (you didn't mention) but you would have to change to a post-1940's torque tube that has the provision for the starter motor as far as I know... Someone else might have another way possibly.. Steve
Justin
11-27-2002 14:38:45
 Re: Re: Adding Electric Start for Allis B Tractor in reply to Steve in N.J., 11-27-2002 06:07:40
You will have a hard time if you do not already have the spot for the starter. (1940 and up model) Mine is a 47 and u slide the starter in and to start it u push the button and it will catch on the flywheel and start it up. So without that hole it would be tough unless you cnahnged the towque tube like someone else entioned. If you do do that as well there will be no kill switch. What I plan to do mine is cut a hole in the magneto and runa wire up by the throttle rod so that it would ground out the magneto (not allowing a spark) Otherwise you have shut the gas flow off in the carb and let it run out of gas. Whcih can also be a good thing. Leaving gas in the carb isn't a great hting to do especially for a while.
Jusitn
