Re: Coolant leak in AC-B
Brian
11-26-2002 06:41:40
Look your block over for cracks down where the sleeves seal. Sleeve seals can be the cause for leaks. Don't worry about any cracks between the cylinders if they are on the head deck. The head gasket will seal these. If you do have a crack down below, good blocks are readily available and easy to find. Reasonably easy job to swap the engine if you need to.
