Re: B is backfiring after sitting three years, what may be the cause?
JustinNY
11-24-2002 17:42:01
Aaron, Do you know if the owner pulled the valve cover off to make sure the valves were free BEFORE he pull started it????? ????? If a valve was stuck which is a very good possibility after that amount of time sitting when he pull started it,it is a very good chance he did some damage to the valves,Ya can pull the Mag apart and clean your points that might help.I would be concerned about the valves!!!!! Justin NY Justin NY
