Fiat-Allis 14C
Simon
11-20-2002 17:49:44
I have a 14C Fiat-Allis bulldozer. Yesterday, when I fired up the engine there was no response on the hydraulics to the tracks, but the blade tilt was ok. So I decided to shut down the engine and start up again - miraculously everything seems to work good.
Today,I start up the engine but there was no hydraulics to the tracks again, but the blade tilt is still ok. So I decided to shut down and re-start to see if it helps, but still no hydraulics to the tracks. The hydraulic fluid level is ok though. What seems to be the problem? Can someone help me on this? Appreciate any and all help. Thanks.
scott
12-29-2003 09:17:18
 Re: Fiat-Allis 14C in reply to Simon, 11-20-2002 17:49:44
hey byron give me a call,469-446-1384 might be able to help each other,thanks.
Byron
12-25-2003 11:29:40
I have a Fiat-Allis 14C with a busted left rear main drive, good condition otherwise, will sell or trade.
Byron
Ernesto Paz
12-25-2003 19:49:43
 Re: Re: Fiat-Allis 14C in reply to Byron, 12-25-2003 11:29:40
i�need catalog parts of FIAAT ALLIS 14C
Thanks.
Byron
12-25-2003 11:27:52
I am looking for a rear main drive for a Fiat-Allis 14C, will consider parts, a junker, rebuilt , whatever.
Thanks,
Byron
steve
11-21-2002 15:32:47
Simon, im not sure what you mean by the track hydraulics. Do you mean it wont go into gear (transmission) or are you really talking about something on the hydraulic tank and valve. If you are on the dozer raise cylinders, the spool in the valve might have cracked causing no raise, just tilt operation. I would repost on www.ibdozing.com (the dozer guys) and expalin more in detail what problem you have.
