D17 Diesel Muffler
kevin
11-20-2002 16:04:19
The 1958 diesel we just got has a "turned down" cast iron header coming off the 4-bolt flange on top of the manifold. This appears to be a factory original header--made of cast iron. The muffler though looks like an old "glass pack" that hot rodders use. The muffler and pipe run down the right side of the tractor. I would like to switch to the muffler through the hood. Is there a muffler available that already has the 4-bolt flange factory-welded or do I need to build and adapter flange/pipe that will provide a way to connect the muffler pipe to the manifold?
david l wilson
11-21-2002 17:29:27
 Re: D17 Diesel Muffler in reply to kevin, 11-20-2002 16:04:19
kevin the original 4 bolt muffler is still avalible through a-c they are about 25.00 i just got one for mine this spring. when you change it over to other muffler would you be interested in selling the low clearance set up you have . i would be interested in it if you do it would work good on my brush hog tractor. let me know please. thanks david l wilson [email protected]
Dan and Cory
11-20-2002 18:24:16
check with a local farm store they can order mufflers. john deere used the 4 bolt flange alot if you can find one with the same pattern and diameter it should work
Jeff
11-21-2002 01:59:20
 Re: Re: D17 Diesel Muffler in reply to Dan and Cory, 11-20-2002 18:24:16
Both my D-17 diesels have the muffler you are looking for. I am sure they are still available.
