D 17 questions
kevin
11-20-2002 06:33:06
Does the final drive and differential housing "share" the same oil? I'm told that to completely drain the final drive housings they have to be removed. Has anyone ever drilled and tapped the low point of the housings and installed a 1/4" pipe plug? Will I still go to heaven if I do this to my D17?
Also, I'm still not clear about the different sumps for the power director clutch, the transmission, differential and the lift. I've drained and refilled the transmission oil, but am having trouble locating fills/drains for the power director, differential and 3-pt lift. (The Operators Manual doesn't even list a differential housing.)
Thanks for any help.
Dan and Cory
11-20-2002 18:32:12
 Re: D 17 questions in reply to kevin, 11-20-2002 06:33:06
No the final drives should be 80w90 gear oil. The best way to intall a plug in the final drives is to drill on the side toward the bottom. The lift, power director, and diff, are the same oil. On the D-19 there are two plugs under the trans and diff.
DanD.
11-20-2002 12:08:54
Final drives do not share oil with any other reservoirs. You're supposed to take the sumps off to drain, but I'm sure most have never been off. Keep them full to the filler hole with gear lube and you'll be fine. You can remove the 8 or so bolts and take the sumps off fairly easily...it wouldn't be that hard. Just get a couple of new gaskets from your dealer for reassembly. My suspicion is that if you drilled and tapped a hole, your plug would be wedged into the gear before it got tight. I don't think there's a lot of clearance between the gear and the sump. The transmission and the differential share the same oil supply. The drain for the power director is right ahead of the transmission..right in line with the power director lever. I believe it's more toward the left side and angles off to the side. If your D-17 is a newer one, the hydraulic and power director share a common oil supply. If it's an older one, there will be a seperate dipstick and breather cap along the right side of the torgue tube. If you have a newer D17, there will be no seperate breather, and you'll have a hydraulic oil filter along the right side near the power director lever.
kevin
11-20-2002 14:40:19
 Re: Re: D 17 questions in reply to DanD., 11-20-2002 12:08:54
Dan,
Thanks for the info--I'll check things out on Thursday. That's a good point about the plug maybe hitting the gear--I take it the gear is pretty close to the housing. There's no dealer within 2 hours of here, but I'll get a couple of gaskets next chance I get.
kjm
11-20-2002 18:30:12
 Re: Re: Re: D 17 questions in reply to kevin, 11-20-2002 14:40:19
Use RVT it`s a better gasket that AC ever made
