Wheel weights
Tyler
11-19-2002 18:36:36
I'm needing a set of front and rear wheel weights for a wd-45. If anyone has a set and would like to sale them please let me know.
john
12-01-2002 09:23:18
 Re: wheel weights in reply to Tyler, 11-19-2002 18:36:36
acording to the dealer parts manual i have, ac made both front and rear weights to mount inside the rims they also had the more common front stack weights. you may also double the rear weights up for more weight. i have a pair of rear weights. sorry not for sale. however i to would like to get my hands on a set of orig. front rim wheel weights and also the front stackable weights.how ever, i understand they are a bit rare. good luck in your search. hope that bit of info is helpful to you.by the way, to any disbelievers i would give the orig. part no's if my manuals were not left at the shop.
dan and cory
11-22-2002 14:10:49
The D series used stack weights they dont fit on the wheels
Dan and Cory
11-20-2002 18:41:28
Try the local dealer. Our local dealer has alot of the rear weights. I didnt know they made front weights for a 45. i have a set for a WC. where are you located?
david l wilson
11-21-2002 17:35:54
 Re: Re: wheel weights in reply to Dan and Cory, 11-20-2002 18:41:28
from what i understand they used the same front weights as the d series used. kind of flat. they mount on top of the front end ahead of the rad. and had a bracket on each side for the hold down bolts.
