B Hydraulics
Joe Westrich
11-17-2002 07:48:06
How do you properly bleed the hydraulics on a model B?
The ram moves very slowly w/o load and not at all
with load. Pump is a rebuilt. Cams etc are all
in good shape. Worked fine until I removed ram and reinstalled. Filled ram and hose the best I
could before installing. Tried loosening seal nut
while under pressure but perhaps did not do it properly. Does pump have to be primed? If so how?
Appreciate any suggestions.
steve
11-17-2002 16:50:57
 Re: B Hydraulics in reply to Joe Westrich, 11-17-2002 07:48:06
I had the same trouble when i rebuilt. The hose stickes out the side of the pump/valve. I believe there is a 1/4 inch pipe plug above the hose pointing straight up. I took out the plug and put the tip of an oil can in it an pumped it up. I screwed the plug in snug and took the hose off the cylinder and put it in a bucket. Started tractor and bumped the hydraulic lever several times. Had to remove the plug and fill the line a second time. When the oil flows good out the hose, put it back on the cylinder and run in and out a few times. Dont worry about getting too much out out the hose. This is a low volume pump, at low engine speed it dont put out much.
