Re: Allis B
Rod (NH)
11-13-2002 14:25:18
Jim,
Make sure you have the #1 piston on top dead center on the compression stroke and not the exhaust stroke. Just a thought.
Rod
DENNIS (WA)DENNO CHOP@AOL
11-16-2002 22:10:23
 Re: Re: Allis B in reply to Rod (NH), 11-13-2002 14:25:18
JIM HAVE YOU RAN A COMPRESSION CHECK ON IT SINCE YOU ASSEMBLED THE ENGINE.? . IF YOU HAVE , IF IT IS LOW MAYBE THE VALVES ARE ADJ. A LITTLE TO TIGHT . TO MAKE SURE YOUR ON THE COMPRESSION STOKE ON NO, 1 CYL. STICK THE TIP OF YOUR FINGER IN THE PLUG HOLE AND ROLL THE ENGINE OVER, WHEN YOU FEEL AIR BLOW OUT AROUND YOUR FINGER THATS THE COMP. STROKE . THEN CHECK YOUR ROTOR TO SEE IF ITS ON NO. ONE WIRE . SOME TIMES IT HELPS TO SQUIRT A LITTLE FUEL RIGHT IN TO THE SPARK PLUG HOLE . BEFORE CRANKING HOPE THIS HELPS.. DENNIS C.
