Re: Stuck Clutch? Couple questions
steve
11-11-2002 10:34:45
this is not uncommon on the C and B tractors a few years older. a little leak on the rear main seal of th eengine allows oil to get on the clutch plate and make it STICKY. Popping it loose like you did normally fixes the problem. I like to remove the starter motor and mix up some water and degreaser and spray it liberally in thru the starter hole and let it run out the bottom. Then hose it out and reinstall starter.
