1939 allis b
max adams
11-09-2002 15:18:32
what i have is a 39 b,and the problem i'm having is after i run it a while and i shut it down for a little bit.the old girl is a nightmare to get started,unless i let it cool down for a while.is this common with the hand cranking type or is there something i can do? thank you in advance,max
Steve in N.J.
11-09-2002 17:48:55
 Re: 1939 allis b in reply to max adams, 11-09-2002 15:18:32
Max,
The ole'girl should fire right back up again. Hand crank shouldn't have anything to do with it.
Could be a few different things, but I would start with checking the points & point gap first. A few fellows here on the board had similar problems and found the condensor to be bad. When they get hot they quit till things cool down, and then she fires right back up again. The other thing I thought of would possibly be a fuel problem, but she's not stalling and quitting on you, she just won't start after you shut it. I would start at the mag, it sounds like it just could be an ignition problem... Steve B.
