CA hand clutch
Darrel L. Stoen
11-08-2002 19:35:05
Hello,
I have a 1953 CA and the hand clutch does not seem to operate! When I pull the lever back during forward motion nothing changes! Any suggestions as to what to do next?
Joe
11-11-2002 20:18:24
 Re: CA hand clutch in reply to Darrel L. Stoen, 11-08-2002 19:35:05
Sometimes the 2 piece axle and clutch is replaced with a solid axle so there is no problem with the clutch slipping. Those little clutches aren't very heavy duty and it doesn't take much to make them slip, and if they aren't really needed you're probably better off without it, for example if you are going to use the tractor for pulling.
George
11-10-2002 06:51:39
Clutch requires adj. if it fails to disengage the drive to the rear wheels when actuating lever is pulled to the rear. To adjust,remove actuator hub retaining screw which is accessible through opening in platform and final drive housing.Rotate actuator hub counter-clockwise (viewed from right side of tractor)until a .005 clearance is obtained between the release bearing and clutch.
Justin NY
11-08-2002 19:55:32
Darrel, Did you happen to just purchase the tractor?Some people when the clutch gets wore instead of fixing it the correct way to fix the problem will drill and pin the hand clutch so it no longer slips .If not check linkage and pull clutch and take a look. Justin NY
