Removing head on WD
Denny
11-07-2002 08:08:27
I need to remove the head on my WD. After removing the valve cover I see several big bolts under the rocker arm assembly. How many of these have to be removed to pull the head and do I have to remove the rocker arm assembly to get to these bolts.
phil
11-07-2002 13:14:50
 Re: Removing head on WD in reply to Denny , 11-07-2002 08:08:27
those are the rest of the head bolts. you can remove the rocker assembly as a unit, just be careful when you put it back on that all the pushrods are in place and pull the head down evenly then torque to 90 lbs.
