Allis G gas tank
Mark
11-03-2002 09:30:08
I have searched the major used parts distributors and even most of the companies that make remanufactured parts and have had no luck locating a new or used gas tank. The old one has rust pits around the mounting bracket and rust has has gotten into the inside of the tank. Any suggestions??
Steve in N.J.
11-04-2002 04:28:34
 Re: Allis G gas tank in reply to Mark, 11-03-2002 09:30:08
Mark,
If you have a good radiator man near you, sometimes they specialize in fuel tank repairs. If the tank is borderline, you may be able to have it repaired. I had my B tank done by my radiator man and he did a fabulous job on it. He put a special coating inside the tank to reseal it up. So far, so good. Mine was "peppered" on the bottom where it sits on the support, and had some scale in it. If it's real bad though, probably better to replace it.... Steve B.
Eric Egland
11-03-2002 16:30:21
Rusty acres has been advertising a gas tank for 125.00 give him a blast. Type in Rusty Acres on your search engine.
Mark
11-03-2002 19:07:16
 Re: Re: Allis G gas tank in reply to Eric Egland, 11-03-2002 16:30:21
yea, I saw that one. I called him the day after he sold his only one, thanks though.
David Maddux
11-03-2002 15:05:27
I can not remember who it is but somebody is reproduceing those tanks. I have seen some at the tractor shows this summer. You might try Norm Steinman his no. is574-342-4545 if he does not have them he might know who does. Good luck.
