WD wide front end info
steve
10-30-2002 16:33:43
Heard of a local tractor for sale. Either a WD or 45. has a wide front end and loader. tractor may have locked motor. Thinking of purchase for repair or sell for parts. "Question is i have heard the wide front is valuable for either the WD or 45. Are they the same? Does it fit the WC also? Do i need to look for something special on the axle or is a wide front all the same? I know about B and C, read all the other posts, but dont remember all i read about the 45.
Denny
11-01-2002 07:25:53
 Re: WD wide front end info in reply to steve, 10-30-2002 16:33:43
All written so far is accurate. If you change the steering box with the front end, I believe you can put any wide front on any WC, WD, Wd-45.
xavier
10-30-2002 17:47:03
The 45 front will fit, a 45, wd or a wc, although the wc used the "wishbone" style, but it will fit.
John (C-IL)
10-30-2002 19:09:10
 Re: Re: WD wide front end info in reply to xavier, 10-30-2002 17:47:03
And the early fronts are 3 bolt and the later ones are 4 bolt once you look at them you will see what I mean. Also check out the center pivot for wear and the top of the spindle where it attaches to the axle for welds. John
Eldon
10-30-2002 19:24:53
 Re: Re: Re: WD wide front end info in reply to John (C-IL), 10-30-2002 19:09:10
I have a 53 WD with the 3 bolt wide front. The handcrank has to come out at an angle to clear it. That makes it a little harder to put a front pump on for a loader.
